Best airflow setup for Lancool LL mesh
justinislit
So I'm building my first pc and I was wondering what the best airflow for Lancool case. Right now I was thinking of my 360 AIO in front and 2 fans on top and one at the rear and deciding if I should go with 2 fans over my psu cover.
360mm front, 2x140mm top will balance the airflow well, if you have a spare 120mm sitting around the rear can also be used but it's not going to help much.
Don't bother with the PSU shroud fans, they just cause extra turbulence and don't have a dedicated intake so the cool air they add is minimal compared to the huge 360mm intake.
The best gaming PC is the PC you like to game on, how you like to game on it
Don't bother buying more fans. The stock fan a decent.
Mount the aio with it's fans to the front. Move the stock fans to the top.
You'll have 1 extra fan.
would the extra stock 120 fan help if I mount it in the rear.
i would keep it as an extra. so you aio can get max flow
