CPU : Amd-Fx 8350
Gpu : Msi Gtx 660
CpuCooler : CoolerMaster Hyper212 Evo
MoBo : Asus Sabertooth 990FX R2.0 (he will be overclocking)
Ram : KingstonHyperX 8GB Dual Channel 1600Mhz
HDD : Seagate Barracuda 1TB
SSD : He doest want one directly but he will get an Samsung EVO 840 120GB
PSU : CoolerMaster G650M
Case : Zalman Z11
Purposes of this build is Streaming and Gaming
https://linustechtips.com/topic/126526-build-for-a-friend/
CPU : Amd-Fx 8350
Gpu : Msi Gtx 660
Case : Zalman Z11
how much will be overclocking with that 212 evo? get a cheaper 990fx motherboard and a better aio cooler
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/126526-build-for-a-friend/#findComment-1682860
@acidydragon I don't have a budget
I need a rough number you want to stay under. If you have no budget, lets build a 20000 dollar machine...
We need some guidance for what you're willing to put into it.
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/126526-build-for-a-friend/#findComment-1682911
k than around 1200$
What kind of dollars are you using?
What do you mean by 'he doesn't want one directly'?
https://linustechtips.com/topic/126526-build-for-a-friend/#findComment-1683033
I'm using American dollars
Mind answering my second question?
https://linustechtips.com/topic/126526-build-for-a-friend/#findComment-1683073
lol sorry xS and i'm just gonna use my HDD that i've got at the moment but i will get an SSD eventually
You can get one now. http://pcpartpicker.com/p/390Ma
https://linustechtips.com/topic/126526-build-for-a-friend/#findComment-1686615
