Hello everyone I'm a 1st time builder. Here's the link to my parts list FOR REFERENCE: https://pcpartpicker.com/list/
MY QUESTION: Does it matter where I've attached my component power cords into the PSU or have I done them right? I'm afraid of the thing exploding, setting fire, arcing, or shorting on me for fear I've placed them into the incorrect PSU outputs / inputs... I know nothing about volts or electricity really. I DO KNOW MY CONNECTIONS TO THE COMPONENTS THEMSELVES ARE CORRECT, just confused on the points on the PSU itself.
I have an ASUS ROG THOR 850w Platinum. I've attached 2 pictures of the input/output ports on the PSU for reference.
Please tell me if I need to change them around, or any safety concerns I should be aware of, or if I've done them correct.
Here's what I've done, and where I've attached the cords to the PSU:
Motherboard: to slots 11 and 12
                                     [using (18+10) to 24 cord]
CPU: to slots 1 and 2
                                     [using 2x (4+4) to 8 cords]
                                     (NOTE: 2x separate cables that attach to CPU PWR1 and CPU PWR2 on motherboard with ends labeled "CPU")
GPU: to slots 9 and 10
                                     [using 2x (6+2) to 8 cords (PCIE)]
                                     (NOTE: 2x separate cables that attach to GPU with ends labeled "PCIE")
HDD: to slot 6
Here's a bunch of electrical garble I don't understand but may be helpful to you guys:IMG_4969.thumb.JPG.735d6bb4ab22a45d82b180f858375a52.JPG
SO HOW'D I DO???
https://linustechtips.com/topic/1264837-help-how-to-plug-into-psu/
As long as you've connected the cables labeled 'PSU' to the PSU you should be good.
MOTHERBOARD: ASRock H97 Pro4 CPU: Intel Core i5-4460 @3.30 Ghz Intel Xeon E3-1271v3 @4.00 Ghz RAM: 32Gb (4x8Gb) Kingstone HyperX Fury DDR3@1600 Mhz (9-9-9-27)
GPU: MSI 390 8Gb Gaming Edition PSU: XFX TS 650w Bronze Enermax Revolution D.F. 650w 80+ Gold MOUSE: Logitech G502 Proteus Spectrum KEYBOARD: Monokey Standard Suave Blue
STORAGE: SSD Samsung EVO 850 250Gb // HDD WD Green 1Tb // HDD WD Blue 4Tb // HDD WD Blue 160Gb CASE: Fractal Design Define R5 Windowed OS: Windows 11 Pro x64 Bit
MONITORS: Samsung CFG7 C24FG7xFQ @144hz // Samsung SyncMaster TA350 LT23A350 @60hz Samsung Odyssey G7 COOLER: Noctua NH-D15
12 minutes ago, jaslion said:
You only need one 4+4 cable for the cpu power. Did you use 2 4+4 cables for it if so that is a problem. Otherwise all good.
Yes the motherboard is an (8pin + 4pin). each CPU cable only does (4+4). I was told each (4+4) on the motherboard does 300watts, but to overclock I'd need to plug into CPU PWR2 (the single 4pin) to ensure that I didn't overload the other CPU power port (4+4) by sending too much watts through it. I have an i7-10700k I plan to OC at around 5.1-5.2GHZ stable and long term. Why... is this a problem?
According to GamersNexus power draw tests for the i7-10700k:
Stock: 134.4 Watts
@5.1GHZ (1.37V SET / 1.34 GET) runs up to 267.6 Wats
