1 minute ago, Alex_pap said:
Alright now i need some help iam gonna buy corsairs 4000D Airflow case and i am going to put 4 rgb fans and one cpu coller in (h100i rbg platinum) and i wanna know wich powersuplie i need to buy for that to be enough
It also has the
MSI GeForce GTX 1660 Ti 6GB Gaming X
for graphics card and the
AMD Ryzen 5 3600X Box
for processor the
MSI MAG B550 Tomahawk
For motherboard
https://linustechtips.com/topic/1264787-help/#findComment-14176593
23 minutes ago, Alex_pap said:
It also has the
for processor the
For motherboard
get a 550 watt PSU, thats the sweetspot. if you want to upgrade your GPU in the future (make the pc future proof) get a 750 watt psu
https://linustechtips.com/topic/1264787-help/#findComment-14176652
so the 550 will be enough for cables and stuff because i dont really know about cables yet its my first build
https://linustechtips.com/topic/1264787-help/#findComment-14176746
