7 minutes ago, PunKy said:
My samsung 970 evo plus 500gb is booting real slow. It takes 40-50s to boot windows 10. Can anyone help please?
Open Task Manager, go to the tab "Startup" and check what it says on the top right at "Last BIOS time".
When you're in that tab anyways, check for programs that open on the startup and Right Click > Disable any that are not needed.
https://linustechtips.com/topic/1264333-need-help-with-my-ssd/#findComment-14172716
yes i have the unnessesary programs disabled like epic games, or origin. last BIOS time is 15.3s
https://linustechtips.com/topic/1264333-need-help-with-my-ssd/#findComment-14172759
