So, got an HDR monitor and have been putting it through its paces. My initial thought is, it looks good in games that support it, and it doesn't look good on the desktop.
I'm wondering if there is a way I could create, essentially, and on/off button for it on either the desktop or taskbar, rather than having to go into the display settings every time to toggle it?
Thoughts?
https://linustechtips.com/topic/1263246-creating-an-hdr-toggle-shortcut/
Thoughts?
What monitor do you have? If it doesn't do at least HDR 600 and have local dimming, desktop experience will look really bad.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
@ddennis002
It's a Samsung Odyssey, so I believe it has something like HDR1000 and local area dimming.
The main thing that I was noticing was that the Windows interface was being washed out.
Also some of the older games I'm playing didn't have some of their textures well designed for HDR, and brings out some of the visual tricks they were trying to use to avoid more complex implementation and points a bright shiny spotlight at them.
23 hours ago, Harry Voyager said:
@ddennis002
Is it the 27"?
Internet Connection
Passmark Score
3dmark Score
Network
