Power Cable Ants
Solved by jaslion,
9 minutes ago, PandaDaddy said:So my power cable for my monitor is getting bugged with ants what is the best way to get rid of it?
Babypowder and isopropyl alcohol mix around the cable. Basically the standard how to keep ants in my ant farm mix but it also works to keep them out (makes surfaces far too slippery and the babypowder attaches to their legs causing them to fall off). If they are going into the monitor that means there is most likely already a nest in there so you should 100% open it before they manage to short it out.
