So I have been thinking of getting a server and colocating it. I found a pretty good deal for colocation, and the big requirements are 1u 3.and 200w max power consumption and impi or similar remote management. I wanted your thoughts on the ideas I have for the space. The server would be used for offsite backups(about 30-50tb would be nice), and running some servers in vms. I am planning on running proxmox on the host. No hard budget, but probably between 1-2k usd
Here are my ideas, from most likely to least likely that Id get. Or give me a totally different idea.
1. 1U4LW-X470 RPSU
https://www.asrockrack.com/general/productdetail.asp?Model=1U4LW-X470#Specifications
About $650 for the barebones, add a $400 3900x, 64 or 128gb ddr4 for about $300 or $600, then some shucked 14 or 16tb for about $300 a pop. Id then add some 2tb sata ssds I have laying around, and some m.2s for boot. Looks pretty optimal to me. Good performance, reasonable price
2. Supermicro 6017R-73THDP+
https://www.ebay.com/itm/Supermicro-1U-12x-3-5-Bay-LFF-X9DRFF-7TG-Xeon-E5-2620-V2-32GB-6017R-73THDP/133438648866?hash=item1f11903222:g:nTYAAOSwLrRdhWTY
Big pro of 12 drives in 1u.
But that seems like it will get pretty close to 200w, so Im gonna need the lower power skus, and potentially only 8 drives.
Also the power connector is on the different side, so that might be annoying.
Also a lot cheaper, but older aswell.
Other  12 bay enclosures you know about? I see a good amount, but power usage is my big issue with them.
Any other ideas?
https://linustechtips.com/topic/1261619-help-me-plan-a-colocated-server/
