3 minutes ago, jvturnup said:
My church has a 2 in 1 labtop connected to a TV for Bible study. Is their a way for me to capture the the TV screen to may labtop so I can livestream it using obs.
The 2 in 1 only has one hdmi out and my labtop is livestreaming the camera feed
HDMI capture card.
Something like:
https://www.amazon.com/Elgato-Game-Capture-HD60-PlayStation/dp/B01DRWCOGA/ref=sr_1_19?dchild=1&keywords=hdmi+usb+capture&qid=1603562747&sr=8-19
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
If the tv is connected to the laptop, its acting as another display already, so you should be able to capture the screen as is in something like OBS
1 minute ago, HanZie82 said:
Will connecting it to the tv still capture only the tv?
If connected correctly yes.
But its not really capturing the TV just the signal the TV gets. But you will need physical access since you need to put the capture device between them.
2in1 --> capture device --> TV
