So recently I picked up a used H100i Extreme Performance and after putting it in on load im getting up to 100 degrees!
Is there a possibility this is to do with thermal paste as I have very old thermal paste on my cpu and have ordered an Arctic MX-2.
Touching the pump, they both vibrate so im guessing they're doing their job?
Corsair Link:
Main RIG:
Motherboard: Z170 Pro Gaming, GPU: GTX 1070 MSI Gaming Z, CPU: i5 6600k, Memory: 16GB (8GB HyperX Fury DDR4 + 8GB Corsair Vengeance LPX DDR4), PSU: TX550M 80+ Gold Certified 550W SSD 1: SN850 500GB M.2 NVME SSD 2: Kingston A400 120GB
https://linustechtips.com/topic/1261018-high-cpu-temps-with-aio/
Just now, emosun said:
did you not apply new thermal paste when you installed the cooler becuase that would not be a very smart idea
I ordered thermal paste but I have to wait for it to arrive, will it make a big impact?
Main RIG:
yes, massive
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Just now, Cyracus said:
yes, massive
I got the cooler for £30 so I thought something may have been wrong with it, but thanks for the help! I'll try stay away from games till the paste arrives ;(
Main RIG:
only in the same way driving a car without any coolant would make a big impact
Yeah, I see your point..
Main RIG:
2 minutes ago, emosun said:
edit : thought it was 100 at idle
Imagine :o
Main RIG:
These are my temps when doing nothing at all
Main RIG:
1 minute ago, emosun said:
well if the machine does nothing at all ever then its fine
What would I average with thermal paste since I wanted to do at least some overclocking?
Main RIG:
fwiw as long as safety features left on in bios it should throttle itself sufficiently to prevent thermal damage (I wouldn't personally rely on that though)
desktop
HTPC
yeah those temp monitor systems are SUPPOSED to work , nobody ever said they always work , cpu's have to die somehow and we're getting a firsthand look at how it happens lol
