Loud click when shuting down : PSU protection?
Solved by Guest,
1 hour ago, electropical said:Hi,
When the computer is shutting down (I turn off the computer using Start>Power>Shut down), a somewhat loud click can be heard (loud enough for me not to be able to locate the origin of the sound) ;
At first, I felt like it was the power supply that was making the sound (Inrush Current Protection?), but now I'm wondering if that's not some other component that's doing it ;
Other than that, the PSU (RM750x) is working fine (at start the fan starts spinning and then stops after a while (passive mode), doesn't make a sound), nothing to complain about.
Any thoughts on what could be causing that click?
It's a relay.
