I'm looking into using my currently gaming rig to run a NAS server (might need to update some parts).
My current reg is s running:
I7-7700k
16 GB og ram
Gtx 1080
256 GB nvme as boot drive.
1 tb for Windows software and gaming.
2 X 4 TB for storage
My plan is to run Windows 10 as my main tool for productivity (video and photo editing) and sometimes gaming.
Then I also want to run a 24/7 NAS server as a virtuel machine, for primarily file storage and secondary streaming my files at home.
My questions is:
• What performance hit should I expect?
• Should I upgrade parts (doubling the ram, 128 GB SSD for buffering and maybe changes to a Ryzen 5 3400g or 3600x)?
https://linustechtips.com/topic/1260392-dobbel-virtuel-machine/
you should upgrade the RAM due to the VM using at least 4 gb to run smoothly.
currently on my workstation at work I run win 10 on a current I7 with 32 gb ram.
on that 2 linux vm and two server 2016 vm.
Well I don't game on that system but it still runs smooth.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/1260392-dobbel-virtuel-machine/#findComment-14139657
Any time you reboot, the NAS goes down. Any time your PC crashes while gaming, your NAS goes down. Any time you have to reboot because of Windows-update or the likes, the NAS goes down. So on and so forth. Also, you don't need to run a NAS in a VM just to share files, since Windows already has the ability to share those over the network.
https://linustechtips.com/topic/1260392-dobbel-virtuel-machine/#findComment-14139658
Has it? Also so I can access them 24/7 online from both PC and mobile? 🙂
And what about if I would need transcoding for streaming? (A feature not a must have)
https://linustechtips.com/topic/1260392-dobbel-virtuel-machine/#findComment-14139670
In your LAN, yes. Over the Internet, you'd need to install additional software, just like with a NAS.
That's also not specifically a NAS-feature. They just typically run Plex for that and you can run Plex under Windows as well.
https://linustechtips.com/topic/1260392-dobbel-virtuel-machine/#findComment-14139677
Why would you need a virtual machine for. nas here, Id just setup a smb share on windows and then devices on your network can access files from it. Performance wise it will be fine, it talkes almost nothing these days to fill a gigabit line with data.
https://linustechtips.com/topic/1260392-dobbel-virtuel-machine/#findComment-14143595
Combine your disks using standalone storage spaces and share it via iSCSI/SMB share. It will be more than enough. If you still wants to run linux, install it on bare-metal and use MDRAID for the HDD drives and configure filesharing via NFS/SMB or block access via iSCSI
https://linustechtips.com/topic/1260392-dobbel-virtuel-machine/#findComment-14158286
