Hmm.. Temps?
Solved by Moonzy,
13 minutes ago, JamiePCMR said:What idle/load temps should my i5 9600k (Stock) average when using a Cooler Master Hyper 212 Black Edition? Thanks
no one can give you an answer because there's too many factor like workload, case airflow, case components, ambient temps and what not
but the hyper 212 black should handle the 9600k at stock just fine
