Suggestions For Bluetooth Transmiters
Solved by rice guru,
54 minutes ago, Hassan170 said:so BTR3k or BTR3 cuz I'm only going to be using one pair of headphones
The btr3k is more powerful has more features , newer , and overall sounds better. The btr3 is older and cheaper either one will work honestly. If you wanna delve more into the audiophile space get into iems with balanced cables and such the btr3k is the better option.
Featured Topics
DreamCat04 ·
Posted in PC Gaming0 -
saltycaramel ·
Posted in Tech News1 -
3
1
1
1
VinSen ·
Posted in New Builds and Planning3 -
2
Fahizzle ·
8
