Hello all,
This is my first pc build and when it boots up, there are green lines across the screen. The resolution is also really low 800x600 and the bios is unusable. Tried to update the graphics driver but it keeps failing and refreshing. The monitor works fine, testing the display out from my laptop.
mother board: msi tomahawk x570
cpu: r7 3800x
gpu: gtx 760, got this from a friend planning to get a 3080.
ram: 32gb 3600 c16
psu: seasonic 750w 80+ gold
Thank you all.
Regards,
https://linustechtips.com/topic/1259168-help-green-lines-on-screen/
4 minutes ago, Jeryjj said:
Hello all,
cpu: r7 3800x
ram: 32gb 3600 c16
I'd chalk that up to being monitor or GPU failure. Easy way to narrow this down is to hookup a different KNOWN GOOD working monitor to the GPU in your PC, or connect this monitor to another KNOWN GOOD working PC to see if the green lines appear on that PC too.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
The monitor is working I use it for work daily. Unfortunately I don't have another gpu. F
  • 1 month later...
