Best Gaming Monitor 2020
Hokum
hey guys I'm planning building my first gaming pc around budget maybe around $900 or 1,000 around there and i was looking for gaming monitor that run 1080p 130 fps around there since im building my pc that can do that if you have any recommendation with links i would appreciate it
You basically need to do the opposite order. Present your part first, then you can get an estimation of a good screen.
Also, what´s the monitors budget?
budget i guess around 200 or 100 and up around there i guess
AOC 24G2(U) - value 144Hz option, considering it's reasonably priced in the region.
Best 1080p gaming monitor maybe Asus VG279QM (280Hz) - costs twice as much.
I edit my posts more often than not
do you have link to that monitor so i can look at it ?
