Lag spikes / Stuttering
DarthBudgie
I get lag spikes in minecraft and fortnite. my fps will go from above 60 to below 30. it is not a software problem. i reinstalled windows and nothing changed. its not a software problem
i have tried
reinstalling windows
disableing gamebar
resetting bios
got a new gpu
switching to ethernet instead of wifi
my specs are a
ryzen 7 2700x
gigabyte b450 aorus pro wifi
16gb 2933mhz corsair pro rgb ram
rtx 2060 super (brand new)
500gb adata nvme ssd (boot drive)
1tb hdd
320gb hdd
120gb adata sp580 ssd
Try in this order (sorry if you have already done some of these):
  1. Update BIOS
  2. Update Drivers
  3. I am not sure what Gigabyte uses for Memory tweaking, but there should be a XMP type of profile setter, you may have to Google it. Essentially this makes your memory run at its fullest potential without OC.
  4. Try re-seating your RAM
  5. Try your other two RAM slots ( also make sure your ram is spaced one apart to utilize dual channel)
  6. Try putting those games on your SSD.
    1. The two games you mentioned run best on a SSD. Minecraft for loading and generating textures and parts of the world and Forknife because it NVIDIA Reflex settings/"texture streaming"/RTX/etc.
  7. Monitor your temps and see if you are getting temp spikes that would cause thermal throttling.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    MSI Optix MAG342CQR 34" UWQHD
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
-> Moved to PC Gaming
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
