Sorry for my laziness, what socket is this?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/125569-i7-920-cooler-help/#findComment-1669128
LGA 1366.
https://linustechtips.com/topic/125569-i7-920-cooler-help/#findComment-1669130
TheSLSAMG, on 09 Mar 2014 - 9:18 PM, said:
LGA 1366.
Thanks.
Cooler Master Hyper 212 EVO.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/125569-i7-920-cooler-help/#findComment-1669138
Hyper 212 EVO if you are on a budget, Noctua NH-D14 or be quiet! Dark Rock Pro 3 if you aren't.
https://linustechtips.com/topic/125569-i7-920-cooler-help/#findComment-1669141
920's do get a bit toasty. A hyper 212 is a good option, but simple water cooling isn't any more advanced that air cooling. A corsair h60 is just as simple to install as a hyper 212 just fyi. I run a corsair h50 on mine and it does pretty good :). But the hyper 212 is a good budget idea, just don't expect 4 GHz on it ;)
https://linustechtips.com/topic/125569-i7-920-cooler-help/#findComment-1669249
H60/H50 are terrible, thin rads and weak pumps. Any similarly priced air cooler will outperform it.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/125569-i7-920-cooler-help/#findComment-1669256
I am not advising one, just saying they aren't any harder to install. I would only go H100i or CM's 220 whatever its called, but those are 100+. The good part about water tho, it gets all of the heat out of the computer, so no CPU heat warms up any other components which is nice.
https://linustechtips.com/topic/125569-i7-920-cooler-help/#findComment-1669270
If I do go with water cooling.... How many Ghz do you think I'll get on it?
Depends what water cooling you get, and what quality of chip you have. I got really lucky and a beast of a chip. I do 3.8 GHz on less than stock votls ;)
https://linustechtips.com/topic/125569-i7-920-cooler-help/#findComment-1669273
I had a 212 EVO on my 920, and was able to get to 3.8Ghz and be fine temp's wise, I never left mid-70's under full load. After that, I was limited by my motherboard not wanting to take more voltage.
Desktop: AMD Threadripper 1950X @ 4.1Ghz Enermax 360L  Gigabyte Aorus Extreme   Zotac 1080Ti AMP Extreme  BeQuiet! Dark Base Pro 900  EVGA SuperNova 1000w G2  LG 34GK950f & ASUS PA248Q Klipsch Reference/Audeze Mobius
Synology Wireless AC-2600
Laptop: Alienware 17R5   Intel i7 8750H  Nvidia GTX1080   3840x2160 4k AdobeRGB IGZO Display   32GB DDR4 2133   256GB+1TB NVMe SSD    1TB Seagate SSHD   Killer 1550 Dual-Band Wireless AC
https://linustechtips.com/topic/125569-i7-920-cooler-help/#findComment-1677480
Evo120 is a good cost conscious option, also you could see if you can pick up a cheap Thermalright true second hand which I used to use on two of my 920's. Overclocking you could get 3.8 maybe 4.0 depending on silicon lottery and stepping of the chip. Beast chip, still holds it's own in todays cpu market today.
Core - EVGA Classified 3 | i7 980x | 12GB Corsair Dominator GT | Lian Li P80 | Corsair 128 Neutron GTX | 2 x WD 500gb Velociraptor | Asus Xonar Xense | 2 x EVGA 590 | Enermax Platimax 1500
Water Cooling - Alphacool NexXxos 360 Monsta | TFC 360 | Alphacool D5 Vario | Alphacool 250 Tube res | EK Supreme HF Nickle Plexi | 2 x EK Nickle Plexi 590 WB | Aquaero 5 XT
https://linustechtips.com/topic/125569-i7-920-cooler-help/#findComment-1680006
