Just now, Ihobonu3 said:
Hello i´m getting a gtx 980 and i have a normal 6+2 power cable and one that has 2 times 6+2
Like main cable from the psu its a modular one btw to the 6+2 thing and then the 6+2 thing has another cable to 6+2
Yep, that's normal; if that's what you're asking.
Most PSU's have a system where the PCIE power cable comes from the PSU and ends with two connectors that can plug into your PSU.
Of course assuming these are the original cables that came with your EVGA PSU.
https://linustechtips.com/topic/1255543-cable-wierd/#findComment-14098318
3 minutes ago, Ihobonu3 said:
i should plug it into the first ''Branch of the cable tough''
Doesn't matter which part of the "branch" you use.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1255543-cable-wierd/#findComment-14098361
