Posted March 9, 2014 I want to install pfsense on a old amd 3600+ computer but the hard drive is dead, so I want to install it on a USB stick (using the USB stick as a HDD), however the installer says if I want to install it to a USB stick I have to install manually. So does anyone know how to install pfsense on a USB flash drive? CPU: AMD 3600 GPU: ASUS DUAL OC RX 6750 XT MOBO: Asus Prime X570-P RAM: 16GB XPG Gammix D10 3000Mhz PSU: Gamdias Kratos P1 650w 80+ Gold OS:Windows 10 pro Case: 4U Rackmount HDD/SSD:Seagate 8 TB/ Patriot Scorch m.2 512GB You can't spell ignorant without IGN...-TheSLSAMG Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 9, 2014 @looney @Ssoele If you tell a big enough lie and tell it frequently enough it will be believed. -Adolf Hitler Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 10, 2014 Here is a nice video that should help you with this: Here is a link to the software he uses: http://www.alexpage.de/usb-image-tool/download/ Respect the Code of Conduct! >> Feel free to join the unofficial LTT teamspeak 3 server TS3.schnitzel.team << >>LTT 10TB+ Topic<< | >>FlexRAID Tutorial<< | >>LTT Speed wave<< | >>LTT Communies and Servers<< Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 11, 2014 Author Here is a nice video that should help you with this No I know how to do that I created a bootable CD and inserted it into my machine and when I tried to install pfsense it said "No SCSI or IDE drives found. If you are tried to install on a different storage medium read the readme." What I am trying to do it use the usb stick as the storage for pfsense to run off of like a hard drive not create a bootable usb drive. CPU: AMD 3600 GPU: ASUS DUAL OC RX 6750 XT MOBO: Asus Prime X570-P RAM: 16GB XPG Gammix D10 3000Mhz PSU: Gamdias Kratos P1 650w 80+ Gold OS:Windows 10 pro Case: 4U Rackmount HDD/SSD:Seagate 8 TB/ Patriot Scorch m.2 512GB You can't spell ignorant without IGN...-TheSLSAMG Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 11, 2014 Just use Win32 Image to 'burn' the ISO onto a Flash Drive. Make sure it's formatted as FAT 32. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 11, 2014 Just use Win32 to 'burn' the image ISO onto a Flash Drive. Make sure it's formatted as FAT 32. This. I've also had a lot of problems with pfSense not installing of USB, this usually works - Unfortunately it might not, in which case use the CD. Though it seems strange that it looks for SCSI/IDE like you mentioned, OP. Never encountered that problem but would suggest trying other versions. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 11, 2014 Make sure to get the right CPU type and bit structure - their download page/version history is a little confusing. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
