So rn i have a mid 2010 macbook pro im fixing for "fun"  but all i see is a white screen
I did end up plugging the drive into a windows pc and found a windows.old files and other windows junk
Is there anyway to Install mac os to it again (i dont have access to the original drive from apple, and i dont have access to a different imac/macbook)
If i find a way to fix this i will update the post as to not waste your time
https://linustechtips.com/topic/1254330-mac-os-help/
You can try holding command + r to access the internet recovery options (if available) if not you may need a second mac to build an macOS installer / usb.
[DESKTOP] CPU: Intel Core i7 8700k GPU: ASUS ROG 2080TI RAM: 64GB Corsair Fury DDR4 Mobo: Asus z390-A Prime
Storage:1x 1TB Samsung 990 Pro SSD 2x 1TB WD Black SSD, 2x 3Tb Seagate  HDD PSU: Seasonic 950W
Monitors: 2x Asus TUF Gaming 24" 1440p  144hz, 2x LG  75Hz 1080p LED
[SERVER/NAS] CPU: Intel Core i7 7700K GPU: Nvidia 1060 6GB RAM: 32 GB Corsair Vengeance Mobo: Asus z-170P D3
Storage:1x 1TB Western Digital SSD, 4x Ironwolf Pro 12Tb HDD, 2x 2TB WD Blue  PSU: Thermaltake 650W
[LAPTOP (MacBook Pro 16")] CPU: 2.4 GHz 8-Core Intel Core i9, RAM: 32 GB 2667 MHz DDR4, SSD: 2 TB
GPU: AMD Radeon Pro 5500M 8GB Display: 16-inch (3072 x 1920)
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14086945
1 minute ago, Electronics Wizardy said:
you can make one from an other mac or get a dvd drive.
Thats the problem i dont have access to an other mac, i have seen tools to do this on windows but i cant figure them out
I will try to do this just in case it does work but no guarantee
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14086957
13 minutes ago, Electronics Wizardy said:
That system is too old for internet recovery. You need to install osx from a usb installer, you can make one from anouther mac or get a dvd drive.
Looks like that machine is actually one of the oldest devices to support that feature. That being said it does require the machine to have a EFI Firmware update to be applied. But who knows maybe it has been already.
Reference:
EFI update for MacBook Pro 15 and 17 Inch: https://support.apple.com/kb/DL1492?locale=en_CA
Computers that can be upgraded to use OS X Internet Recovery: https://support.apple.com/en-us/HT202313
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14086959
Here's some additional documentation for ya.
https://support.apple.com/en-ca/guide/mac-help/mchlp1599/mac
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14086961
it should be able to boot from a linux or windows usb aswell for testing. HOld option for a boot menu.
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14086966
Thanks i will check it out
But i did try it and it was a no go
Im hoping apple made a way to flash the firmware after the fact
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14086967
Tried holding option having tried holding it while a windows usb is in it but i do have a cent os key to try
Also this is what i mean by white screen it does still play the start up noise
I haven't tried hooking it up to a display but i will try to
Edited by piercetorres
Including more information
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14086973
You can just install Windows without a license key. Select the option I don't have a product key when it asks in the installer.
I would try resetting the SMC since it should at least show something like the Prohibitory Sign or a Question mark since macOS isn't installed. I believe for your machine, you have to remove the battery and hold the power button for at least 10 seconds.
Resource: https://support.apple.com/en-ca/HT201295
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14087001
I put in a cent os installation usb cause i had one lying around and nothing showed up
Tried to reset it using the removable battery method and nothing happened it still only shows white
Could one of apples other chips being stopping it from running properly
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14087030
Take out the hard-drive and try to boot. That should give a no disk error, that would tell us if its a firmware error. Then we can go about fixing it depending on the result.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14087112
first try internet recovery. hold down option(alt), command and r at boot. if you see a spinning globe then internet recovery works.
if not you'll need another Mac to make a bootable installer to get macOS working on it. you could ask around to see if anyone in your circle has one you could use for it.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14087385
Took out the drive and nothing changed, so im guessing its a firmware error
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14088129
Update: i tried resetting the smc (i think thats what its called), i tried entering recovery mode, tried the linux boot mode thing, the point is i tried almost everything i could find on the internet and nothing is working, i feel like its a lack of mac os on my device, but i cant know for sure. i will try and meet up with a buddy and see if i can make a mac os usb key or what ever its called.
If it somehow works i will update
And thank you all for your help
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14089411
Plug the hard-drive back in.
Do this vv
Parameter Random-Access Memory (PRAM) and Non-volatile Random-Access Memory (NVRAM) store configuration information about your Mac. To reset the PRAM/NVRAM, follow these instructions:
  1. Restart the Mac, then press and hold down the Command + Option + P + R keys when you hear the start-up chime.
  2. Continue to hold down the keys mentioned in the previous step until you hear the second start-up chime, then release the keys.
  3. Wait 5 mins and shut down the mac.
After doing this. Shut down the mac and do this.
  1. Restart the Mac, and then press and hold down the Command R keys when you hear the start-up chime.
  2. Release the keys when you see the Apple logo.
  3. When the Mac has finished starting up, choose Reinstall OS X from the OS X Utilities menu, then click Continue.
  4. Follow the instructions that appear until you finish the process.
If the second thing does not work then you would need a USB installer.
Desktop :
Laptop :
https://linustechtips.com/topic/1254330-mac-os-help/#findComment-14089942
