Can I plug in corsair QL or LL series fan in Lighting Node Pro form RGB Strips kit?
20 minutes ago, DudeWazap said:Oh wow thanks thats super helpful. so I would just leave the fans that came with the AIO connected to the cooler pump and just connect the new fan into this fan hub and all should be good correct?
Yup.
Not sure if I mentioned it already, but you can't mix multiple fans on one of these hubs. Can't for example have three QL and three LL fans on it for example.
20 minutes ago, DudeWazap said:I did have one more question since Corsair has so many hubs and it's a bit confusing to me since I'm new to RGB stuff.
I do see that they have a ICUE Commander pro. is this a HUB to plug in any type of fan and LED strip by Corsair?
I see it has 2 USB headers so I wouldn't need a splitter if it all goes on that correct?
The Corsair Commander Pro does what the Node Pro does, plus extra.
Corsair RGB fans have two cables on them, an RGB cable that plug into a hub and a PWM cable for actual speed. The Commander Pro has 6 PWM ports, so you can connect the fans to that directly.
The Commander Pro indeed also has a USB hub built in.
This would be your setup with a Commander Pro:
You would still needd the RGB Fan LED Hub to connect the fans to, so they can connect to the Commander Pro.
If your fans come with a Node Core, you can also use that, because of the USB hub on the Commander Pro.
