1 minute ago, LWM723 said:
Would a standard 110v light dimmer switch wired inline with a standard 12 volt PC fan work?
No, AC dimmers work on a different principle from DC variable sources.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
26 minutes ago, LWM723 said:
@AbvdosOne How so ir's just a rheostat doesn't matter whether ir's ac or dc?
AC dimmers haven't been rheostats in decades. Rheostats are terribly inefficient (and borderline dangerous, thermally) for non-industrial applications.
Everything AC is solid-state now days. Dimmers chop the AC waveform at a specific point in each cycle to get the desired power output. At absolute minimum, the control circuitry inside is expecting to be powered from AC and not DC, so it probably wouldn't even start. Also, the control circuit is looking for the zero crossing each half cycle to synchronize the chopping, so DC would probably confuse it.
Network:
@AbvdosOne NOT true, and your explanation is misleading hogwash. I just opened a dimmer switch and lo and behold there is a rheostat in it an NO "circuitry". How did you manage to come up with this BS. And I hooked it up to a 12v PC fan and it works! Learn what your talking about before you post and look stupid.
  1. Spell my name right if you actually want to tag me.
  2. Read the Wikipedia article.
  3. I told you what's true of modern housing dimmer switches; I have seen AC rheostats in (extremely) cheap lamp dimmer adapters, but they waste all the energy not sent to the output device (in the form of a dangerous amount of heat). Your failure to include a reference to or picture of the part you're (ab)using is not my fault. I tried my best, sorry.
  4. I know quite well what I'm talking about, thank you, which is why I bothered to try and help you (I literally have a degree in EE).
Network:
Just now, LWM723 said:
This is is a new, just purchased, in-wall dimmer switch
Mind sharing a picture? I don't doubt you at this point, I'm just curious now.
2 minutes ago, LWM723 said:
rest of what I said still applies
You could still be a little nicer with the "I think you're wrong, here's what I see".
Network:
Nobody:
People on the Internet: Hey I know I asked for help with this thing but I was JK I actually know everything about it and you're all wrong and stupid.
Why do I feel like this is 80% of help threads? 🙃
12 minutes ago, LWM723 said:
@akio123008 Then what do you call the rotary switch inside this light dimmer rhat makes the light brighter and dimmer. By the way, this switch is for incandescent bulbs.
Did you disassemble the switch and pull the control rheostat out? Or are you connecting to the screw terminals on the outside?
(brrowed from https://sound-au.com/project157.htm)
There is still a controller rheostat in a solid-state dimmer, I'm not disagreeing with that.
Network:
@akio123008
Rheostat, adjustable resistor used in applications that require the adjustment of current or the varying of resistance in an electric circuit. The rheostat can adjust generator characteristics, dim lights, and start or control the speed of motors.
@AbydosOne I pulled the rheostat out of the enclosure as I want to mount it without the enclosure. As for a photo, may take a couple weeks to develop the film :)
@AbydosOne  The only things inside the mounting enclosure were the rheostat and what looks like a large resistor, assuming it's a electrical AC noise filter (not needed for 12v DC).
I told you I know what a rheostat is. However, you appear to think that a rheostat is the only way to control the current in a circuit. A rheostat controls output power indeed, but not all devices that control power in a circuit are rheostats.
A rheostat is a very inefficient and crappy way of controlling power in a circuit. Most modern light dimmers don't use rheostats to control the output power.
The rheostat mentioned here is purely for control, this rheostat isn't part of the power circuit.
The rotary "switch" may be a rheostat, but the actual part of the device that controls the output power isn't one. At least in a design that isn't from the 30s.
You seem very capable and well informed.
It seems like you didn't actually need anyone's help.
Guest
