     So is there a way to update the drivers for the Realtek onboard audio? Or is the version you have the one you are stuck with. I was looking into buying a modmic but my version of Realtek drivers(but not my motherboard) is incompatible.
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/125316-updating-realtek-audio/
Go to your motherboard makers website and update the drivers that way. They are normally kept up to date.
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/125316-updating-realtek-audio/#findComment-1665985
Wait, what?   How could they be incompatible?  the modmic is just a normal mic, I doubt it's incompatible with your drivers.
Mystery is the source of all true science.
https://linustechtips.com/topic/125316-updating-realtek-audio/#findComment-1666089
There are known incompatibilities with various onboard or discreet sound solutions and they have a list of them on their site. I have no earthly idea why that is but I don't want to buy something that won't work.
https://linustechtips.com/topic/125316-updating-realtek-audio/#findComment-1666415
Don't buy the 3.0 if you don't want incompatibilities.
https://linustechtips.com/topic/125316-updating-realtek-audio/#findComment-1666448
The 3.0 has compatibility issues with certain audio drivers/chips
https://linustechtips.com/topic/125316-updating-realtek-audio/#findComment-1666714
My modmic 1.0 doesn't work very well with the soundblaster Z - lot of noise on the line when its boosted. I don't know why they sometimes end up being incompatible but they do. Not all mics work with all sound setups.
Nah, that'll happen with most cheap mics.
https://linustechtips.com/topic/125316-updating-realtek-audio/#findComment-1668326
