Hey guys,
So today I bought a brand new SanDisk ultra 32g.
I inserted it into my system and I instantly opened CrystalDiskMark to check the  device's speed.
After it finished, I opened the device and i found 2 files there. [SanDiskSecureAccessV3.1_win.exe, SanDiskSecureAccess Settings]
I was wondering what it was for... so I opened the .exe file and I setup a password.
2 Seconds later the device became write-protected and I CANNOT delete, format, delete the vault that was created, move files, or load files into the USB. (basically it became inoperable & useless to me)
I tried contacting SanDisk support but they said nothing can be done and I should return the device.
I tried some basic "diskpart.exe" commands but nothing helped. [select disk# > attr disk clear readonly]  - No luck there.
I also tried poking around inside of the vault program ~ it looks something like this image. There is no option to delete the vault or revert the changes. (at least to what i could see)
So here I am, in a time of great need, I reach out to you guys.
Is there any hope? I sure "hope" to hear from you guys soon!
https://linustechtips.com/topic/1252905-sandisk-vault-problem/
