Hey guys ,  please help me on this
please share some  tweaks/settings  to play GTA 5  at decend playable stage
my system
Hp pavilion 15ab249 ne laptop
intel i7 6500U
geforce 940M 4gb
4GB Ram
500GB  Seagate HDD
Nb: Upgrading components is not possible (empty pocket)
Waiting for your's Valuable Suggestions
https://linustechtips.com/topic/1252819-help-help-help-gta-v/
how many FPS do you average with low settings?
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1252819-help-help-help-gta-v/#findComment-14073862
You should check out of those mods from gta5-mods.com that optimizes the game by removing various things from the visuals and so on.
You're gonna get a hard time playing GTA 5 with those specs.
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1252819-help-help-help-gta-v/#findComment-14073866
i didn't check it, is there any native options or a third party App to check It
all my settings is currently low still i fave some stuttering  when driving through city
https://linustechtips.com/topic/1252819-help-help-help-gta-v/#findComment-14073869
okie lemme check it
https://linustechtips.com/topic/1252819-help-help-help-gta-v/#findComment-14073873
That is more than enough for story mode, and for online as long as you stay in lobbies without a ton of players.
I do recommend you toss in an SSD and maybe another 4GB of RAM.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1252819-help-help-help-gta-v/#findComment-14073888
my system
intel i7 6500U
geforce 940M 4gb
4GB Ram
500GB  Seagate HDD
probably the best ways to tweak you setting is to turn on windows game mode and upgrade you drivers for your graphics and always make sure to close all backround apps!!!
and also one more thing, your graphics card or the entire laptop might not be runningg on required Mhz speed
https://linustechtips.com/topic/1252819-help-help-help-gta-v/#findComment-14073901
