Have you turned your fan speed up?
Specs
https://linustechtips.com/topic/125260-help/#findComment-1665481
Your gpu will never be under the stress furmark puts it under. I would say at most in games it would probably reach 60C at most!.
Go for it.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/125260-help/#findComment-1665482
help me guys. now i overclocked it , it reaches 81 degrees maximum. is it okay?
Fermi ran pretty hot. I'd say 81c is fine under Furmark.
https://linustechtips.com/topic/125260-help/#findComment-1665588
If you're not confident and don't know what you're doing, you shouldn't be overclocking. One wrong move and you can cook your card.
Generally, cards in the low 80C range are fine.
Go google a guide on how to properly overclock your card. They will tell you what is a safe temperature and voltage range to have your card running at.
https://linustechtips.com/topic/125260-help/#findComment-1665590
