Budget (including currency): $1200
Country: United States
Games, programs or workloads that it will be used for: AAA games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I’m not to sure what is inside atm but I plan on looking up what’s exactly inside the Steam machine to make sure.
Hey everyone! First time posting here and I have sort of an odd question for everyone here.
I am in possession of a steam machine beta console that was given out to only around 300 people. My brother entered the sweepstakes that happened in 2013 and ended up being one of the lucky ones to actually win one.
My question to you is what can I actually do with it now? Is there any way that I can upgrade this thing and maybe turn it into something of an updated gaming pc? Is it too far gone that no new tech will actually be able to fit inside of it?
I think it would be a cool little project to work on and have as a second gaming PC since it really hasn’t been touched since 2014.
Let me know what you guys think or if there is any more information that I need to give to be able to help.
Thank you!
-Colton
https://linustechtips.com/topic/1252133-steam-machine-beta-console-build/
You surely could. Seems like it's made of off the shelf components. So as long as you keep in mind the small form factor while buying components, it should be easily upgraded.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
