SATA to USB with power from PSU
Solved by mahyar,
10 minutes ago, T_Hastings said:My problem is that I can't find cables that would let me power the drives from the PSU while connecting them to a USB port. Everything I saw connects to both the SATA and the power port of the HDD's, and that would require additional power adapters, rendering the whole idea of repurposing the case and PSU impractical. So is this just a design-thing, or the drives need to get their connections from the same source?
no they dont you can use a normal sata cable to bridge from adaptor to hdd and not directly conecting it adaptor
