GPU fan speed at 0% but Fan Spinning at 4000RPM
SepLS
Hi, I have MSI Rx 570 Armor 4g OC and I have some problem. As soon as I turn on the PC the GPU Fan Speed is running at 4k RPM, and I tried to monitor the Fan Speed using GPUZ and at the Fan speed (%) is 0 but the Fan Speed (RPM) is 4k RPM, and no matter what I change it wont slow down until I shutdown the PC. even I check the Fan Speed using HWMonitor and the AMD Driver and its same the Fan Speed is at 0 RPM
here are the Screenshot from the GPUZ, AMD Driver, and the HWMonitor
and as you can see the GPU Temp is LOW
download DDU, and AMD's driver from their website
run DDU and reinstall the GPU driver
-sigh- feeling like I'm being too negative lately
  • 8 months later...
did you solve it? I have the same problem
Try a newer driver.
Also, for whatever reason, AMD cards really lag on the fan speed. My Vega 64 takes up to 5 minutes for the fan to actually slow down, though it usually gradually ramps down by then.
"Don't fall down the hole!" ~James, 2022
"If you have a monitor, look at that monitor with your eyeballs." ~ Jake, 2022
