Hey all,
I'm new to this forum and was wondering what y'all think of this build I've been planning out. I don't know if I'll go through with this as I'm also considering getting a(nother) laptop; my current one is on its last legs. Without further ado, here it is:
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Mobo: MSI Z87-G45 Gaming ATX LGA1150 Motherboard
RAM: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory
Drives: Samsung 840 EVO 120GB 2.5" Solid State Disk
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Backup drive?: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Graphics: Asus GeForce GTX 760 2GB Video Card
Case: NZXT Phantom 410 (White) ATX Mid Tower Case
PSU: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
OS: Microsoft Windows 8.1 (OEM) (64-bit)
Wireless card: Rosewill N900PCE 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter
If you couldn't tell, I did this through PCPartPicker, here's the link: http://pcpartpicker.com/p/36CAw
This is for CAD, audio production/recording, gaming and productivity/web surfing.
I'll be going to college/university in September if that makes any difference.
Thanks in advance for any input!
https://linustechtips.com/topic/125170-possible-pc-build/
I can't really see anything wrong with it.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/125170-possible-pc-build/#findComment-1664447
nice selection, wouldnt change a thing.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/125170-possible-pc-build/#findComment-1664448
get only 8 GB of ram and a 4670k, and use that money for a better graphic card, gtx 770 ;)
also, pick an msi gaming card, you will get vga boost with your msi gaming motherboard, and it will look much nicer
Ryzen 5 2600X / ASRock Fatal1ty B450 Gaming K4 / G.Skill RIPJAWS V 16GB (2X8) 3000Mhz CL15 / Gigabyte RTX 2060 Super Gaming 8GB OC / Corsair RM650X 2018 / Crucial BX500 240GB / Seagate Barracauda 2TB 7200RPM Cooler Master MasterBox E500L /  ASUS TUF Gaming VG27WQ // Rog Orion / Corsair Harpoon RGB Pro / Cooler Master MasterKeys Lite L / Xbox One Red Sport  Special Edition Controller for Windows
https://linustechtips.com/topic/125170-possible-pc-build/#findComment-1664474
Good, although I would spend slightly more if you're going to overclock that processor.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/125170-possible-pc-build/#findComment-1664482
What specifically?
Processing power is more important to me than graphics. The 760 is good enough for what I need.
I looked at the msi 760 and it said it was too long for the Phantom 410. I guess if I'm not putting a fan by the drive slots it'll be fine. I'll look into that.
Do you have any preference of color? the kingston ram's not the cheapest you can get, there's cheaper ram for 16gb of 1600mhz and stuff.
Ideally red and black. I haven't put any effort into executing that yet though. and yeah, 233mhz wouldn't make too much of a difference.
https://linustechtips.com/topic/125170-possible-pc-build/#findComment-1664525
What specifically?
oh sorry didn't notice you had 1866mhz, still, there are 1866mhz ram stuffs for cheaper :P
Diamond 5 in League :)
https://linustechtips.com/topic/125170-possible-pc-build/#findComment-1664534
Are you planning to sli?
Are the only projects you're going to be working on from uni?
https://linustechtips.com/topic/125170-possible-pc-build/#findComment-1667521
The only thing i would change is the power supply. The CX series isn't the best from what I heard. Good build overall, here's the link with the different power supply. http://pcpartpicker.com/p/36WTR
PC Specs
Intel i5 4670k 4.2ghz @1.20v | Cooler Master 212 Plus | Asus z87-A | Fractal Design Define R4 |Hitachi 1TB 7200rpm HDD | 2x Samsung 840 EVO | Seasonic 520w m12II | Crucial Ballistix Sport 8gb DDR3 1600mhz | PowerColor 7870 GHz edition | Razer Blackwidow Ultimate 2013 | NZXT Hue RGB Controller
https://linustechtips.com/topic/125170-possible-pc-build/#findComment-1667536
They're great for a budget PSU. Even better when you swap out the stock fan for a Noctua.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/125170-possible-pc-build/#findComment-1667549
The power supply i chose is cheaper, fully modular, and certified gold. IMO I would opt for the RM series over the CX series any day.
PC Specs
https://linustechtips.com/topic/125170-possible-pc-build/#findComment-1667563
