Hi again!
Im looking to clone a 350gb hdd and I have been looking for a cloner. Not looking to spend more than $50 USD. Link to the one im planning to buy (https://www.newegg.com/wavlink-wl-st334u-dock/p/0VN-0069-00001?&quicklink=true ) 1- My computer is Windows 8, will it be fine when connected to use with Macrium Reflect? 2- Will I need a external CD-ROM to install the cloners software (it comes with one)?
Thank you
https://linustechtips.com/topic/1250675-cloning-help-2/
Most likely you can download newer drivers from the internets.
If you can find those. (Maybe try before buying then you will be sure. ;))
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1250675-cloning-help-2/#findComment-14053824
If you are buying that cloner,  you won't need to use any software.  You just put 2 drives in the device and push a button to clone it.  doesn't even need to be connected to a computer.
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
https://linustechtips.com/topic/1250675-cloning-help-2/#findComment-14054042
Yeah but I wouldn't be able to work with the partitions.
https://linustechtips.com/topic/1250675-cloning-help-2/#findComment-14054599
