What PSU do you have?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1250660-help-me/#findComment-14053611
That 8pin is for the CPU then (generally marked EPS). GPU 8pin should be marked GPU or PCIE.
Depending on the model of the PSU (as asked above), it's might not support 8pin GPUs (too weak). Or if the cable did come with the PSU, but you have lost it, then you'd need to find a new one. Easier way would be the cable, but that might not always be very succesful, in which case you'd need new PSU.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1250660-help-me/#findComment-14053617
I have that 8pin cpu power labelled eps and the gpu 8 pin power labelled pcie but the 8pin dont match to the socket on the rx570
https://linustechtips.com/topic/1250660-help-me/#findComment-14053625
Are you 100% sure about this? If the power cable is labelled as PCIe, it should work with your RX 570.
https://linustechtips.com/topic/1250660-help-me/#findComment-14053658
pic?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1250660-help-me/#findComment-14053669
Im 100% positive I've check the 8pin many times before putting it on but it doesnt fit should I try using a 6pin to 8pin adapter or do I have to buy a new PSU instead
https://linustechtips.com/topic/1250660-help-me/#findComment-14053670
