Hey guys, i just build my first PC and everything running smoothly. But when i check crystaldiskinfo it said my WD Blue SN550 only getting 3x2 speed, even though it can support to 3x4.
On Crystaldiskmark, it's only getting 1800/mbps and 2200/mbps as advertised.
My motherboard is MSI b550 gaming plus and i checked on the manual, it support 3x4 on the first m2 slot.
How can i change it? thanks.
https://linustechtips.com/topic/1250649-nvme-not-getting-max-speed/
it could be auto turning off because of a usb port or sata drive that's plugged in
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
1 minute ago, Milanizer said:
i only use one drive now for my OS. With another sata SSD for upgrade next month.
Which usb ports can alter pcie speed?
idk which ones in specific, but my motherboard won't let me use nvme 4x if I either have a sata plugged in or I'm using the usb 3.2 header
That would be mentioned in the mobo manual, check there.
F@H
GPD Win 2
You sure first slot isn't the lower one, it's the case on my x470 board?
Edit: top slot is one according to manual. But bandwidth is dependent on CPU installed
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
Yep, pretty sure i double checked on mobo manual. The m2_1 is the one with frozr shield. Although the lower one is also supported 3x4, according to the motherboard.
I'm sorry after double checking i can't any information about why it changed to x2 even though it's supported x4.
What CPU is used?
Gaming PC:
Linux PC:
7 minutes ago, Milanizer said:
ryzen 3 3300x.
Ok it has 16x4 + 4x4 for storage, if you're using sata then that might be the issue.
Gaming PC:
Linux PC:
no, i don't use any sata. my nvme is the only installed in my build. haha.
That's pretty weird then. Only GPU and nvme in slot m2_1 and not a ton of USB stuff?
Might want to try just using the top back USBs.
Edit: your ssd is only using pcie 3.0x4 though so either m2_1 or m2_2 should work full speed.. :s might want to try m2_2 just for lulz
Gaming PC:
Linux PC:
My GPU is pretty old though, it's a R7 240 from MSI. i used is a placeholder until big navi launch before buying new GPU. Is it the problem?
Yep, also change my keyboard and mouse to top usb labeled 2.0. no change at all.
Check edit..
Gaming PC:
Linux PC:
I don't think that's the case, my drive can support gen 3x4.
haha maybe gonna change to m2_2 tomorrow then.
I know but first slot is 4x4 native and 2nd is 3x4 native, worth a try. If that fixed the issue, then it's a compatibility issue
Gaming PC:
Linux PC:
ooh okey i get it yeah. haha. Because the m2_2 is native 3x4 right? allright. Thanks!
Gonna do it tomorrow though.
