If you can fit it, there aren't many better air coolers:
http://ca.pcpartpicker.com/part/noctua-cpu-cooler-nhd14
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/125057-need-cooler/#findComment-1663055
cool thanks, I'll look into them
https://linustechtips.com/topic/125057-need-cooler/#findComment-1663098
Depends on how hard you want to OC it. I'd recommend a bequiet Dark Rock 3 or Shadow Rock 2. They're relativeley inexpensive and cool well while being quiet. If you want to overclock really hard I'd suggest to go with the Noctua NH-D14, stated above, if you can fit it.
  • Phanteks PH-TC12DX
I think what you meant was the PH-TC14PE ? :P
who cares...
https://linustechtips.com/topic/125057-need-cooler/#findComment-1665655
What's the system being used for?
https://linustechtips.com/topic/125057-need-cooler/#findComment-1667713
U14S is fine to add here. With two fans it compares with D14.
Yeah agreed. A 2500K didnt even need a nh-d14, and with 3570K's heat disappation bottleneck a nh-d14 is a waste. I'd get a nh-u12s or a nh-u14s to have some space in your rig and still have the same cooling performance as a nh-d14. Theyre also quieter than the nh-d14 and comes with a pwm fan.
https://linustechtips.com/topic/125057-need-cooler/#findComment-1673051
