Ps now on pc problem
Go to solution Solved by Nerdom,
You should be able to get it working with an Xbox one controller as well. Generic controllers will probably be hit and miss.
https://www.windowscentral.com/playstation-now-pc-terrific-when-it-actually-works#:~:text=To use PlayStation Now you,PS4%2C you're golden.&text=Better news is that the,appears to work just fine.
R9 3900x, 32gb 3200mhz corsair dominator RGB, 1070Ti Founders Edition, HP 512GB PCIe M.2 SSD
https://linustechtips.com/topic/1249541-ps-now-on-pc-problem/#findComment-14043379
Thanksman
https://linustechtips.com/topic/1249541-ps-now-on-pc-problem/#findComment-14043470
