Budget (including currency): $1450 (NOT INCLUDING GPU AND POWER SUPPLY) I already have a RTX 3080, and a RM850x 80 Plus Gold Fully Modular ATX Power Supply
Country: Canada
Games, programs or workloads that it will be used for: I want fastest everything and highest frames, hoping for a Ryzen 3900X
Ryzen 3900XT OC to 4.4Ghz -B550 Aorus Pro - 32Gb 3600Mhz Corsair - RTX 3080 ASUS TUF OC - O11D Dynamic Tempered Glass - 2x 1TB m.2 SSD - 850W GOLD Corsair - Alien Ware Ultra Wide 3440x1440p - MSI MAG Core Liquid 360R RGB - Razer X Chroma - Razer DeathAdder Elite - Windows 10 Pro
https://linustechtips.com/topic/1248571-need-help-building-please/
Country: Canada
Highest frame rates will be seen on a 10900K or potentially on Zen3 when benches come out.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
What holds more value down the road? i7 10700K or Ryzen 3900XT?
it depends on use case
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
Monetary value depends entirely on what the makers release, or don't release next on the platform. Historically, only the peak CPU's of a platform retain significant value, the rest being proportional to the performance.
Whats a good gaming mother board to get for AMD Ryzen 3900xt?
How is this build?
PCPartPicker Part List
CPU: Intel Core i5-10600K 4.1 GHz 6-Core Processor  ($372.75 @ shopRBC) don't need a 3900x for a gaming rig.
CPU Cooler: Deepcool GAMMAXX L240 69.34 CFM Liquid CPU Cooler  ($95.99 @ Amazon Canada)
Motherboard: MSI MAG Z490 TOMAHAWK ATX LGA1200 Motherboard  ($214.99 @ Memory Express)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($71.99 @ Newegg Canada) 32gb is overkill.
Storage: ADATA XPG SX8200 Pro 1 TB M.2-2280 NVME Solid State Drive  ($157.99 @ PC-Canada)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  ($93.99 @ PC-Canada)
Total: $1007.70
Generated by PCPartPicker 2020-09-18 22:03 EDT-0400
