so I am looking to buy a really bad gpu just so i have one with my FX 6300 until ai buy a new one. so if anyone is willing to help me and can scroll a lil bit to tell me which one is good because i dont know anything about old gpus, if not well thats okay too. The site is in bosnian dont bother there are pictures when u open it and scroll a lil bit u can see the graphica card model. And the higher the number before "KM"(currency) is the more expensiv3 it is so consider that. You can ignore this if you are too lazy to help xd. https://www.olx.ba/pretraga?trazilica=graficka&do=35
https://linustechtips.com/topic/1248397-scuffed-graphics-card-help/
Honestly, all those cards are about 10 years old by now. Your cpu would be fine with a GTX 760 or GTX 950 or maybe GTX 960. Those would be the cards to look out for.
Given your selected budget, this one would be a good choice
I like that it has the aftermarket cooler on it, the original one was very loud.
