Just now, anybody? said:
just like mine?
biostar A320MH
Ryzen 3 2200G
1 stick of 8gb ram
no gpu
thanks for helping man
yes, it would work. but there are far better psus out there for a similar price, so not sure why you would want to stick with a bad quality one that won't allow any upgrades
https://linustechtips.com/topic/1248342-power-supply-options/#findComment-14033728
More than enough for your specs, but if you tell us what your budget is and where you're located, we could find you a PSU which'll last longer and be good enough to support many future upgrades.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1248342-power-supply-options/#findComment-14033736
my budget is quite rough around 50 usd or 2,500 php im from the philippines thanks for helping
https://linustechtips.com/topic/1248342-power-supply-options/#findComment-14033747
Hey there,
I would highly recommend that you go for corsair CX450, as it also seems to be the most suggested one by experts. Cooler Master 650W PSU is also an okay option, but I would personally recommend the former.
Glade to be of any help! Cheers!
https://linustechtips.com/topic/1248342-power-supply-options/#findComment-14034770
