3 minutes ago, Mpire934 said:
so a Ryzen 7 3700x won't run the speed very well?
most Zen 2 CPU runs 3600MHz on single rank just fine, though it's only officially supported up to 3200MHz. I've seen some chips not being able to go above 3200MHz, albeit quite rare.
it's up to luck, but 3600MHz with 1800 FCLK should be achievable in most zen 2 CPUs.
expect to lose frequency as memory rank goes up (more sticks/capacity in each slot)
AMD stated that 3900x only support up to 2666 on quad rank 128gb configs. read it in a reddit post
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006760
So go Ryzen 7 3700x
with 3200mhz cl16 Ram
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006771
2 minutes ago, Mpire934 said:
So go Ryzen 7 3700x
yea would be fine for gaming
you could consider 3600 CL16 ram if they're not much more expensive
or 3600 CL18 RAM if you're doing bandwidth intensive tasks (games arent bandwidth intensive)
3200 C16 ~= 3600 C18 in term of latency
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006786
4 minutes ago, Mpire934 said:
So go Ryzen 7 3700x
I wouldn't worry about going with 3600MHz.  You're not gonna have any trouble with that in terms of FCLK.
A crappy mobo and RAM kit might not play well though, but I wanna say I really only saw that problem with ASUS TUF and 3600 16-19-19 RAM kits.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006792
Gaming is my main priority with my pc so i will go with 3200mhz Cl16
my Budget is eaten by the ROG 3080 OC
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006794
-snip-
Are you trying to say that CL18 has higher bandwidth than CL16?  Because that's how that came across.
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006796
What's your budget for RAM?
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006798
3600 vs 3200 that he showed
should've made it clearer
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006799
So then you know 3600C16 is better than 3600C18 in terms of bandwidth right?
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006803
Just now, Mpire934 said:
200 USD
How much RAM?
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006805
hmm, care to educate me? (not sarcasm, genuinely wanting to learn)
i just know bandwidth = MT/s x 8bytes x efficiency
lower CL = higher efficiency i assume, though by how much?
is it as much diff as 3200 vs 3600? (around 13% diff i think)
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006814
Well I don't know about the formula you're using to figure out the theoretical bandwidth, but I can tell you that lower CL will result in higher bandwidth.
And if comparing kits with matching latencies then you always want to go with the faster kit as it will have higher bandwidth and also the other benefits it brings to Ryzen platforms.
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006835
31 minutes ago, Mpire934 said:
200 USD
You can buy a very, very good 16GB kit for that price or a very good 32GB kit for $220.
https://linustechtips.com/topic/1245036-ram-speed/#findComment-14006890
