I'm OC my 9900k to 5.0ghz. Currently it is stable at 4.8ghz all core, 1.19 vcore.
I'm struggling to get 4.9 stable. Currently vcore is 1.25, but still crashing.
My cache ratio is set to auto, and looks like its set to 4300 mhz. Should I adjust this higher to be within ~500mhz of core clock?
https://linustechtips.com/topic/1243877-9900k-overclock-help-pls/
Target within 300-500MHz range. Do note that just like core clock, extra cache clock requires more voltage to be stable in most cases (since the CPU is doing work faster)
Desktop benching:
1 hour ago, JakeSublime said:
Oh I didn't know you needed more vcore with higher cache speeds. 😮 thats one of my problems there! I'll keep fooling around and come back
-300 is almost always stable, 4.9 1.25v still has alot of voltage headroom, just bump it up a bit more
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
After a while, i got 5.0ghz stable, with cache left at auto, and vcore at 1.295v. It touches 80-85c under max load but its okay. I really wanted 5.1 tbh but oh well.
I also got my 1080 ti to 2088mhz under load :D and it stays at 45c or under. UserBenchmark said my GPU has a performance rating of 151% which is in the top 1% of 1080 ti owners. Im a lucky boi ig lol.
Yeah you're right at that thermal point where 85c is hot enough imo. Not bad.
Keep working on it. OC the cache a little bit, see if you can keep the 1.2950v and run 4.5 to 4.7ghz cache.
I tried really hard to get my cache speeds higher, but i simply cant get it to come out of auto.
I even tried upping the voltage by 15 mV but still gets BSODs. :( And I dont want to increase my voltage any higher at ALL.
I have to say, this CPU sure acts like it needs to be delidded... but its soldered... :( I delidded my old 7700k and got ~20C drop WITH 200MHz increase to 5GHz.
It's okay though, I accept my system's current performance. It lives up to my wishes.
--------- UPDATE! ---------
I bought an EK velocity WB, EK 240mm slim radiator, and I'm connecting my cpu to my GPU cooling loop.
Oh. And I'm delidding my too. F that solder.
Also. I'm considering running direct die liquid metal.
Lastly, I just might lap the die down by 0.1mm-0.3mm.
Looking for 5.4GHz all-core, baby.
I'm going to post in another thread about my progress on that as things happen.
