RTX 3090 / 3080 (3x8 pin AIB) with Corsair SF750 question
talos91
Go to solution Solved by Jurrunio,
16 minutes ago, talos91 said:
Is this safe? Nvidia recommends using separate cable connections for each 8 pin connector, i was wondering if this was the same for Board partner versions.
Nvidia follows PCIe power specs (unlike AMD which violates it from time to time) so this is just a "in theory better" thing, not a must.
17 minutes ago, talos91 said:
Is it safe to connect the extra CPU 8 pin to the 3rd 8 pin connector on the 3080/3090?
No, EPS12V for the CPU has two 12V pins in which are ground for PCIe 8pin, you will cause a short if you managed to do that.
To my fellow SF750 owners, if anyone is getting an AIB 3x8 pin RTX 3080 / 3090, are you going to run the 2 x 8 pins from one rail and use the 2nd rail for the last 8 pin? Is this safe? Nvidia recommends using separate cable connections for each 8 pin connector, i was wondering if this was the same for Board partner versions.
I noticed the SF750 has 2x GPU cables and 2X CPU 8 pin cables which kinda make no sense for an SFX PSU. I don't understand why they would include 2 x 8pin CPU cables. I don't think i've seen an ITX board require more than 1 x 8 pin connector. Is it safe to connect the extra CPU 8 pin to the 3rd 8 pin connector on the 3080/3090?
Sorry for all the questions and bad structure, i'm just wondering what i need to do to prepare for my upcoming card. Thanks!
Desktop benching:
Okay cool, thanks for clearing that up. So in summary, just use the 2 cables from the PSU to the GPU and use 3 of the 4 (8pin) GPU connections and i should be safe right? Thanks for the advice.
Yep
Desktop benching:
Source? (I'm interested)
CPURyzen 7 5800X Cooler: Arctic Liquid Freezer II 120mm AIO with push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
MotherboardASRock X570M Pro4 GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO Case: Antec P5 PSU: Rosewill Capstone 750M
Monitor: ASUS ROG Strix XG32VC Case Fans: 2x Arctic P12 PWM Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
RX 480 breaking PCIe slots on older boards? R9 295x2 literally drawing well over 400w with only two PCIe 8pin?
Desktop benching:
Again, a link please so I can read up on it?
https://www.google.com/amp/s/www.tomshardware.com/amp/reviews/graphics-card-power-supply-balance,3979-5.html
https://www.tomshardware.com/reviews/amd-radeon-rx-480-polaris-10,4616-9.html
Nvidias have shunts to monitor power draw from the connectors and the slot itself, but AMDs only monitor the GPU die.
Desktop benching:
The 5700XT has a sensor specific to total card power draw. (ASIC Power) It's not just Nvidia with that sensor.
Thank you for the links.
It is true that Navi gets memory power monitoring despite it not being in the GPU package (like Vega) but ASIC power in Hwinfo (previously Chip power) is NOT the full power draw of the card.
https://www.hwinfo.com/forum/threads/gpu-power-confusion.2930/
It's partly.monitored and the rest are calculated based on load.
and if you break down the name, Application-Specific Integrated Circuit has nothing to do with the whole card, the VRM, PCB traces, fans and more are not a type of ASIC.
Desktop benching:
10 hours ago, Jurrunio said:
May 2017, 2 years before Navi. Navi uses the ASIC sensor for full GPU power draw reporting.
That's unfortunately the most up to date post I could find on hwinfo forums related to this. Any links I can read about it then? Cuz if you look at the BIOS, Navi cards always draw more than what the BIOS limit is set to. For example, Tom's HW found that the RX5700 reference card draws about 175w in games and 180w in Furmark, but at the same time the BIOS for the RX 5700 reference card has the power limit of only 150W. Why does the card not follow the limit written into the BIOS?
and since we're at it, can you show me where the power monitoring chip is on the PCB? To monitor the power draw of the whole card, this sensor must be an external thing in order to take VRM efficiency and PCB losses into consideration.
Desktop benching:
I'm going off my own testing of having a power monitor at the wall, and comparing to the ASIC sensor in a way that is as unaffected by other system power draw as possible. Accounting for my PSU efficiency curve, the ASIC sensor comes within margin of error for total from-the-wall power draw accuracy.
doesnt sound credible I must say. Also you cant rule out that it's only partially based on calculations and not fully measured.
Desktop benching:
It's entirely up to you to believe or disbelieve, but seeing as you have no evidence to the contrary from the last 3 years, you're far more likely to be off than I am.
Every rounded number for every sensor is based on a calculation, even when measured. Especially if they combine multiple sensors worth of information.
I'm certain the tom's hardware one is within a year old
I actually started a thread for this in Hwinfo forums, we'll see.
Desktop benching:
And it confirms with what I'm saying though. ASIC sensor shows 180w at stock, power draw is at 180w. With the +50% power limit, it draws 225w according to the ASIC sensor, and within margin of error the same amount from the wall. (per my own tests)
Then why doesnt the power limit value in BIOS apply to ASIC reading directly? Why use core power instead when it's possible to monitor the whole card?
btw if ASIC power is just the new name for chip power in the past, then this problem existed since the start of GCN
Desktop benching:
I don't know what you're asking here. A power limit change shouldn't interact with the power draw sensing capabilities.
Because the power going to the core is the most variable, and the most relevant to the functionality of the card. VRAM power rarely if ever changes, but core power fluctuates based on load.
ASIC power is not chip power on the 5700 XT, it's total board power draw. (at least from my tests) This means power draw from the 8-pin, 6-pin, and PCIe slot added together. Chip power is a different sensor entirely. (the "Core Power" sensor)
power limit works according to power draw number, how you get the power draw number matters a lot.
1. Thinking secondary power rails always draw similar levels of power is why Furmark blew up so many old cards. Because individual power limit for each rail is too expensive, AMD and Nvidia end up reducing frequency significantly when the driver detects Furmark running in the short term and in the long run, beefed up secondary rails so they would survive Furmark
2. Not using whole card power draw to trigger power limit means the card can't directly protect PCIe slots and PCIe cables from drawing more power than specified
Desktop benching:
Reply linked to this:
https://www.hwinfo.com/forum/threads/which-gpu-power-option-is-the-total-gpu-power.6676/#post-26569
so yeah, it's not a proper sensor to the level of Nvidia. Close, not quite.
Desktop benching:
That's not what was stated.
"This is not quite clear, but "GPU ASIC Power" should be the closest to total GPU power, yet it might not include all rails."
There isn't enough info to prove one way or the other, and it may or may not provide accurate readings for draw from all power sources. Since it does match up with my 5700 XT testing for it to be accurate, it's safe to assume that the 5700 XT ASIC sensor is a total card power draw sensor that covers everything.
Why would you want a 3080/90 with 3 x 8 pin PCIe connector setup anyways with an sf750?
CPU | Intel i9-10850K | GPU | EVGA 3080ti FTW3 HYBRID  | CASE | Phanteks Enthoo Evolv ATX | PSU | Corsair HX850i | RAM | 2x8GB G.skill Trident RGB 3000MHz | MOTHERBOARD | Asus Z490E Strix | STORAGE | Adata XPG 256GB NVME + Adata XPG 1T + WD Blue 1TB + Adata 480GB SSD | COOLING | Evga CLC280 | MONITOR | Acer Predator XB271HU | OS | Windows 10 |
https://www.hwinfo.com/forum/threads/amd-navi-card-power-monitoring.6683/#post-26591
this is the full answer
so it's meant to cover everything, but it cannot prevent overspec power draws down each source like Nvidia cards can
Desktop benching:
"(and this is not just the case of AMD, but all other vendors)"
Nvidia is the exact same.
