Are buying these parts a good deal or not?
Hello, I just want to ask if are these parts are worth buying, I will translate the price to USD.
CPU+Motherboard (Bundle): Ryzen 5 2600 (no cooler) and B450-DS3H for around 12,000PHP ($250)
RAM: 2x8gb @ 2666mhz for 3,000PHP ($62)
SSD: 1TB WD GREEN SSD for 5,990PHP ($124)
Case: Rakk Haliya mATX White 2950PHP ($65)
PSU: Inplay 450W 80+ Bronze Rated 1900PHP ($40)
Graphics Card: Palit 1050TI Single Fan (used 2months) for 3500PHP ($73)
Cooler: Ryzen 7 AMD Wraith Prism RGB 1950PHP ($41)
Total Cost: 31,290PHP ($650)
everything looks pretty good except the RAM, You should go for a higher speed like 3200mhz. Ryzen really benefits off faster RAM. Also I believe your PSU is not modular. Considering it's a smaller case, you should try to get a semi modular power supply if you can.
41 dollars for a Wraith Prism is too much IMO. You could get a Deepcool Gammaxx 400 or Hyper 212 which gives you much better cooling performance.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
Wraith Prism is about as good as those coolers
Huh, you're right. I stand corected.
Main Rig :
Laptop :
but they should also be about 20 dollars cheaper (at least in the US, not sure about OP's country)
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
i found one thats about 3 dollars cheaper than the wraith prism, can I OC with this cooler?
I looked up if its comaptible, and people are saying that the ds3h cant handle a 3200mhz ram, it blue screens when it boots
for the PSU, i found a CX450M, fully modular PSU, but the price is around 85 dollars. Is that a good deal?
thats pretty expensive, I say around $60 you can find a semi modular psu for that price. Fully modular is not necessary unless for specific purposes. Semi modular is still very good. Make sure it has 80+ also. Brands like EVGA, Cooler master, seasonic, corsair are all good
