I need help choosing what CPU im going to use for a build using the RTX 3070, MSI B550 MAG WIFI, G.Skill Ripjaws V 3200 16gb, Corsiar 650 Watt Bronze, Samsung 870 EVO 1TB, and a Cooler Master NR600. I need to know if a Ryzen 3 3100 will be enough to keep up with the 3070 or will I need to get a 3600.
https://linustechtips.com/topic/1241931-cpu-selection-for-rtx-3070/
a ryzen 3 will probably be a poor choice. a r5 3600 should be enough.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
Wait for the 3060 and/or RDNA2 and get a better CPU, unless you're gaming at 1440p Ultra or 4K.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
3600 now, nothing less. Then you upgrade to some Ryzen 4000 whenever it is needed.
Corsair iCUE 4000X RGB
ASUS ROG STRIX B550-E GAMING
Ryzen 5900X
Corsair Hydro H150i Pro 360mm AIO
Ballistix 32GB (4x8GB) 3600MHz CL16 RGB
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Gigabyte RTX 3060 Ti GAMING OC
Corsair RM850X
Predator XB273UGS QHD IPS 165 Hz
iPhone 13 Pro 128GB Graphite
