I've got a weird problem, while folding only one of my 760's and my GT 610 would show up and my 760 was hardly getting any PPD while my 610 was getting impossible PPD as you can see in the picture below.
After looking around in the help section on the F@H site I added my other 760 in another GPU slot but even after doing that(and disabling SLI) my second 760 isn't showing any progress despite Precision X and GPUz showing it under full load.
That was after I ran it for a few hours to be sure that it was working properly. Can anyone tell me what's going on?
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/124105-fh-help/
Try deleting that slot and adding it again. That helps me sometimes
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/124105-fh-help/#findComment-1651055
I forgot to mention that I had done that several times, I've also tried re-installing F@H with no luck.
https://linustechtips.com/topic/124105-fh-help/#findComment-1651078
Are the temps on that 760 ok? Might be being throttled down if they aren't.
Also, when you uninstalled, did you check the box to also delete work units? Might be a bad one. BTW - don't do that if you have active, good ones. Let them complete before doing that, or all that works is lost as well...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/124105-fh-help/#findComment-1652596
Yea the temps are fine, they hover at about 70-ish I've never had my 760's thermally throttle as they're ACX cards. I don't think I checked that box I'll give that a try once my current units are done.
https://linustechtips.com/topic/124105-fh-help/#findComment-1653334
That seems to have worked, though I still cant see how my 610 is getting similar PPD to my 760's, do you know why @Whaler_99?
https://linustechtips.com/topic/124105-fh-help/#findComment-1653395
Just temp PPD calcs and weird WU's - I would say as it gets closer to getting done, PPD will adjust...
https://linustechtips.com/topic/124105-fh-help/#findComment-1655438
