Budget (including currency): $1100 usd
Country: usa
Games, programs or workloads that it will be used for: fortnite, cad, snowrunner, racing games, streaming
Other details
PCPartPicker Part List: https://pcpartpicker.com/list/WyTC3t
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($199.99 @ Best Buy)
Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) ATX AM4 Motherboard  ($199.99 @ B&H)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($62.99 @ Amazon)
Storage: Western Digital Blue 500 GB M.2-2280 Solid State Drive  ($59.99 @ Newegg)
Storage: Western Digital Green 1 TB 2.5" Solid State Drive  ($89.99 @ Amazon)
Video Card: MSI GeForce RTX 2070 8 GB TRI FROZR Video Card
Case: Asus TUF Gaming GT301 ATX Mid Tower Case  ($99.99 @ Amazon)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($85.99 @ Newegg)
Operating System: Microsoft Windows 10 Home Full 32/64-bit  ($119.04 @ HP)
Total: $917.97
Generated by PCPartPicker 2020-08-31 13:42 EDT-0400
https://linustechtips.com/topic/1241027-first-build/
2070 isn't in production anymore, neither is the 2070 super. Your best bet is to wait for ampere or get a 5700 XT if you want it now
https://linustechtips.com/topic/1241027-first-build/#findComment-13975079
Where are you going to get that card, Don't buy windows for that insane amount
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1241027-first-build/#findComment-13975094
Just now, LoganLemx said:
i do not need it now but i would like to use a nivida that does not break the bank
Any specific reason you want an Nvidia card? The 5700 XT is a really great performing card that absolutely does not break the bank.
https://linustechtips.com/topic/1241027-first-build/#findComment-13975102
because i like them
You're putting yourself in a really bad position if that's the way you're going to shop for computer parts
https://linustechtips.com/topic/1241027-first-build/#findComment-13975115
1 minute ago, LoganLemx said:
because i like them
That is like saying I want to stay intel because I like them, meanwhile you loose money / performance
Reminder⚠️
https://linustechtips.com/topic/1241027-first-build/#findComment-13975119
where can you get them cheaper
Almost everywhere ebay for example
Reminder⚠️
https://linustechtips.com/topic/1241027-first-build/#findComment-13975122
ok so you want me to go with the msi card
What MSI card?
https://linustechtips.com/topic/1241027-first-build/#findComment-13975125
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1241027-first-build/#findComment-13975135
You should wait for Ampere to be announced literally tomorrow, and pick whichever card fits your budget out of the lineup and wait for it to become available for purchase. I wouldn't build right now personally, I'd wait for Black Friday and Cyber Monday. If you have to get the parts now and don't want to wait I'd go for something like this, your build list is kind of all over the place with pricing(I'm guessing because you're going for aesthetic and cool over price to performance. This would be a better bang for your buck other than the RTX card(but you said you only want Nvidia if not then go for a 5700XT), you can get a cheaper board too if you don't need WiFi. Again, if you want a Nvidia card wait a couple months for Ampere to be readily available before you build the computer.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1241027-first-build/#findComment-13975148
12 minutes ago, Mateyyy said:
14 minutes ago, Slottr said:
What MSI card?
ok everyone how is this
PCPartPicker Part List: https://pcpartpicker.com/list/vs27f9
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  ($179.99 @ Newegg)
Storage: Western Digital Blue 1 TB M.2-2280 Solid State Drive  ($104.50 @ Amazon)
Video Card: Asus Radeon RX 5700 XT 8 GB TUF Gaming X3 OC Video Card  ($389.99 @ Newegg)
Total: $1123.44
Generated by PCPartPicker 2020-08-31 14:11 EDT-0400
https://linustechtips.com/topic/1241027-first-build/#findComment-13975166
Total: $1123.44
The B550-A Pro will work just as well and it's $40 cheaper, the SSD is SATA (not that it makes much of a difference but eh), the 5700XT TUF X3 is a dumpster fire, I'm not going to comment on the case, and the PSU is not necessarily bad but out of place in a build with a 5700XT.
https://linustechtips.com/topic/1241027-first-build/#findComment-13975180
what do you suggest for the psu and gpu i would like to stick with the asus tuf gaming theme
https://linustechtips.com/topic/1241027-first-build/#findComment-13975193
Total: $1123.44
The motherboard @Mateyyy linked is a perfectly capable board and $40 cheaper than the one you picked. The WD Blue linked is a Sata SSD, you can get an Nvme for cheaper. The Asus Tuf 5700XT is a bad card, so many issues. Are you set on that Asus case? You can get a mesh front panel and tempered glass case for much cheaper than that one. You can also get an 80 plus gold 600w psu for around that same price. I'll just link you a build so you don't have to worry about it.
https://linustechtips.com/topic/1241027-first-build/#findComment-13975211
So you would rather have aesthetics over price to performance? Is there specific reason you only want Asus Tuf components besides that?
https://linustechtips.com/topic/1241027-first-build/#findComment-13975214
35 minutes ago, Mateyyy said:
Video Card Asus GeForce RTX 2060 SUPER 8 GB DUAL EVO OC V2 Video Card $409.99 @ B&H
Power Supply Phanteks AMP 550 W 80+ Gold Certified Fully Modular ATX Power Supply $96.98 @ Newegg
If streaming's not that much of a priority for you and don't care for any of the other Nvidia specific features, you could go for a 5700XT instead and get a decent bit of extra raw performance.
I'd recommend these models that are similar in terms of price to the 2060S above:
https://pcpartpicker.com/product/jbK2FT/msi-radeon-rx-5700-xt-8-gb-gaming-x-video-card-radeon-rx-5700-xt-gaming-x
https://pcpartpicker.com/product/3YTzK8/sapphire-radeon-rx-5700-xt-8-gb-pulse-video-card-11293-01-20g
The MP33 is DRAM-less though, so ideally I'd go for something else.
The Kingston A2000 seems to be out of stock, since that's usually really cheap and a decent option, so something like a Silicon Power A80 for a little bit more would definitely be worth going for.
https://linustechtips.com/topic/1241027-first-build/#findComment-13975222
PCPartPicker Part List: https://pcpartpicker.com/list/gct7f9
CPU Cooler: Cooler Master ML120L TUF Gaming Alliance Edition RGB 66.7 CFM Liquid CPU Cooler
Memory: Team T-FORCE VULCAN TUF Gaming Allian 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($57.99 @ Newegg)
Storage: Team MP33 1 TB M.2-2280 NVME Solid State Drive  ($99.99 @ Newegg)
Video Card: Asus GeForce RTX 2060 6 GB TUF OC Video Card  ($339.99 @ B&H)
Power Supply: Phanteks AMP 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($96.98 @ Newegg)
Total: $1074.92
Generated by PCPartPicker 2020-08-31 21:45 EDT-0400
https://linustechtips.com/topic/1241027-first-build/#findComment-13975265
