Hi there,
I'm looking for a laptop that is thin, and good for gaming and programming. I'm going into my second year of university studying Software Engineering and I'm looking for a laptop to bring to and from university.
I have been looking at the Razer Blade 15 with 2070 Max Q and the OLED 4K screen, 10th Gen Intel i7 but it's very difficult to justify the £2,300 price tag (As much as I'm sure it's worth every penny!).
It does not have to be light per-say, but it must not be bulky.
Does anybody have any suggestions? If you require more info then please ask.
Thanks.
Main PC [ CPU AMD Ryzen 9 7900X3D with H150i ELITE CAPPELIX  GPU Nvidia 3090 FE  MBD ASUS ROG STRIX X670E-A  RAM Corsair Dominator Platinum 64GB@5600MHz  PSU HX1000i  Case Lian Li PC-O11 Dynamic  Monitor LG UltraGear 1440p 32" Nano IPS@180Hz  Keyboard Keychron Q6 with Kailh Box Switch Jade  Mouse Logitech G Pro Superlight  Microphone Shure SM7B with Cloudlifter & GoXLR ]
Server [ CPU AMD Ryzen 5 5600G  GPU Intel ARC A380  RAM Corsair VEGEANCE LPX 64GB  Storage 16TB EXOS ]
Phone [ Google Pixel 8 Pro, 256GB, Snow ]
https://linustechtips.com/topic/1239907-laptop-for-programming-gaming-and-general/
The newer ryzen laptops look great, granted several limitations on configurations presently such as the 2060 being the highest gpu option.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Do you happen to have a specific recommendation so I can get a reference point?
This should be helpful:
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
What he ^ said. Avoid the asus tuf laptop if you care about colors, the panel is trash.
desktop
HTPC
