17 minutes ago, Pondum said:
Does the NZXT H510 Elite have sufficient airflow to keep a i7-10700k and a 3000 series card nice and cool? I'll be using a Kraken X63 to manage the CPU temps.
Thanks
Take a look at this
Written article:
https://www.gamersnexus.net/hwreviews/3496-nzxt-h510-elite-case-review-making-things-worse
Or YouTube video:
Look at the first place for the test while the front panel is removed, look toward the bottom to see stock
https://linustechtips.com/topic/1239665-airflow-question/#findComment-13964836
Thanks
There are better cases out there, but if you already have it, it's probably fine, though we don't know how hot the 3000 series cards run so it's all speculation.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1239665-airflow-question/#findComment-13965091
Well I assume a 3070 won't be much hotter than a 2080 Ti. Thanks though!
https://linustechtips.com/topic/1239665-airflow-question/#findComment-13966046
A 2080ti would generally be a bad pairing in an H510. Personally I only recommend up to about an RTX060/RX5700 (non XT) before temperatures start getting very warm and GPU's reduce boost clocks
https://linustechtips.com/topic/1239665-airflow-question/#findComment-13966412
