Not sure what's going on, I've been noticing this a few months now. Been cleaning the surrounding VRM heatsinks with isopropyl alcohol. It looks good for a month or 2 and then it comes back. What's going on any ideas? I hope it's not time for a new motherboard... This board is I believe 2 years old now. Thanks in advance.
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/
Yeah I'm confused on what it is too. I've been reading around, others have said it might be a leaky thermal pad... Or maybe the thermal paste on the thermal pad coming out? Not sure how MSI does it, but maybe that's how they did it? I've seen this sort of weird wet residue, or oil, whatever it is on EVGA video cards. Other's have said it's the thermal pads EVGA uses on their cards doing that. Maybe same thing on the MSI boards? It's just frustrating... I clean the residue around the VRMs and behind the board twice now, and it just keeps coming back. Did a stress test after cleaning the surrounding area just now with Prime95 and wait 10 minutes. MOS temp reached 84 degree's celsius. After stopping the stress test, the temp did come down rather quickly. Now the MOS is sitting at 48 degree's.
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958818
18 minutes ago, RobFRaschke said:
Is that an overclocked 9900K stressing the vrm that hard? 84 under load is pretty warm!
Nope stock lol. Well to be fair... My AC broke yesterday and getting a new one today. So the MOS temp is with no AC in the house lol. Even then, stress testing brings the MOS temp I think to 60ish. 84 is high I agree, but even 60ish shouldn't be a problem. I hear these VRM's can run at 100 degree's with no ill signs. So what type of cheap thermal pads did MSI put on this $400 board :| If that's the issue, which seems like it is. :(
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958854
If it hasn't been happening since day 1, it's not flux. That would have started from the first heat cycle. And yeah, 84 is completely safe, just higher than usual. 60s with a normal room temp for ambient is more what I would except to see from a MEG ACE grade board. And leaching from thermal pads isn't unheard of at all, it's actually more likely in a higher performance thermal pad than from a cheap one. As I recall, especially Philips.
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958906
Yeah my board is a MSI MEG Z390 ACE. Cleaning around the tiny heatsinks for the VRMs shouldn't ruin the thermal pads right? I'm at the point of giving up to clean it to be honest lol. Cleaned it last time, and it just came back anyway lol. I know isoproply alcohol cleans off thermal paste, just not sure on how thermal pads behave. Would it be an issue if some of that alcohol found it's way under the vrm heatsinks or thermal pad? Considering how quick alcohol dries lol.
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958923
13 minutes ago, Apollyon2020 said:
OP losing their shit over a minor thing
You know, you could've just googled this. Some thermal pads leak, it's nothing to worry about. Obsessing about it and constantly cleaning your mobo and stuff like that is just silly when spending 30 seconds googling would've cleared the situation up.
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958945
I have googled it, and nothing really comes up. Clearly why I came here to ask. Considering someone on here must of seen this issue, or have experienced it themselves. Maybe it's minor to you, but not for me. I don't understand why you had the need to post a comment if your intent wasn't a positive one. Anyways, thanks.
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958948
I apologize, my intention wasn't to sound like an asshole. My intention was to inform you that such a leakage is a minor thing, only cosmetic, and you have nothing to worry about it.
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958949
If it's normal, then I'm cool with it. Just never had this before and thought it was some 'MSI' thing. Same way how EVGA's thermal pads leak. Wasn't sure about VRMs doing this. Anyhow, no worries and thanks for clearing it up.
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958951
Yes just thermal paste from the thermal pads, doesn't mean it's cheap, it happens with most if not all boards, it's not conductive so it won't hurt anything.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958959
Good to know. Well I guess cleaning the surrounding area with isopropyl alcohol is pretty much useless lol. If any of the isopropyl got under the thermal pads, it shouldn't effect it right? Considering how quick the alcohol dries.
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958962
I mean probably won't, you can check the vrm temps afterwards and see if it did or not.
Build Log:
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13958964
You won't degrade the pads from a little alcohol hitting the sides.
https://linustechtips.com/topic/1238824-leaking-vrm-pads-help/#findComment-13960579
