I just upgraded my PC from:
CPU: Pentium G4560 -> I7-7700K
Ram: 8 GB DDR4 -> 16 GB DDR4
My current GPU is a 1060 3gb.  I want to upgrade my GPU to match my CPU and ram performance.  I would prefer to spend $400 or less.  My question is what is the best power for value that I can get for my GPU, and would you recommend me pairing a 1060 with something like a 1660 Super or should I sell my 1060 and just get a more powerful single card?  ]
I'm gonna buy my cards used on Ebay.
I can get a 1660 Super for $229 Brand New on there.  Willing to spend up to $400 if it means more performance, just don't know what to get.
1660 Super Deal: https://www.ebay.com/itm/ASUS-NVIDIA-GeForce-GTX-1660-SUPER-OC-Edition-6GB-GDDR6-PCI-Express-3-0-Gra/193484676212?epid=5036279263&hash=item2d0c95dc74%3Ag%3AVDUAAOSwab5eztGj&LH_BIN=1
https://linustechtips.com/topic/1238508-need-help-picking-the-right-gpu/
I'm gonna buy my cards used on Ebay.  I can get a 1660 Super for $229 on there.  Willing to spend up to $400 if it means more performance, just don't know what to get.
The new price for a GTX 1660 Super (in the US)  is about 230-250 USD. No need to get it used if that's the same price.
What resolution and refresh rate is your monitor? What games do you play?
you can sell your current GPU and get a 5700xt which should be under $400, or save up a bit for the new ampere and big navi GPUs later this year.
also, rest of system specs?
Edited by Oswin
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
144 HZ 1080P 1 ms response time.  I mostly play Warzone but I want it to be able to play other games high FPS
B250 motherboard
Plenty of storage (SSD + HD)
450 W Power Supply.
Is the 450 W PS a problem?
1 minute ago, CooperMyers said:
B250 motherboard
450 W Power Supply.
which specific unit?
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
wattage wise, it's enough for a lot of gpu's, what model though?
I got a white CX 450M
yea it's a decent unit and afaik does have 2 8pin pcie connectors, you could get a 5700xt for around that price, or if you're streaming, a 2060 super should also do the job.
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
 get rtx 2070 or rx 5700xt for that price , there is a newegg page in ebay , just google it , it sells everything pretty cheap but its only there for the USA
On 8/25/2020 at 2:24 PM, alirafi321 said:
 get rtx 2070
Where will he get that?
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
